Integrated
Bindery Systems
British Engineering logo
Link to IBIS LinkedIn page
Hovmand Pile Handler trolley HPL-100
Not yet released, availability subject to testing
The Hovmand pile handler HPL-100 is a lifting trolley system which can pick up a large sheet pile (up to 380mm pile height), move it to the Smart-binder and place the pile on the lift table of the sheet feeder SB-095, SB-096 or SB-097. This reduces the Smart-binder stop-time by reducing the pile reload time.
The HPL-100 is an alternative to the PLT-100 loading trolley system for the SB-095 and SB-096, and is the only trolley that can be used with the SB-097.
The HPL-100 is mounted on wheels so it can be easily moved around the factory. An integral battery-powered electric motor is used to raise and lower the forks.
A separate 'pile-support tray' allows the forks to be lowered and withdrawn when the pile is placed on the feeder lift table.
Sequence of operation:
  1. Sheets are built up into a pile (up to 380mm height) on the 'pile support tray'.
    Note: an optional stacking table ST-100 may be supplied to assist creation of this pile
  2. The HPL-100 forks engage with the support tray and lift the pile. The 'hold -own' bar may be used to prevent the pile being disturbed while being moved
  3. The pile is transported to the Smart-binder sheet feeder and placed on the feeder lift table. The HPL-100 is then removed and the pile is slid into the feed position
  4. When all the sheets have been fed into the Smart-binder the support tray is removed and the HPL-100 loads the next pile
    Note: multiple support trays may be provided
View a video of the Hovmand Pile Handler trolley in operation
IBIS Hovmand sheet pile loader HPL-100
HPL-100
'Corrugated'
pile
support
tray
Pile hold-
down bar
Lift forks
(motor driven
up/down)
